Will a low battry keep an XS11 from starting?
  • XJOK2PLAY
    replied
    Hope she fires up for ya Thursday night, MasherMoto.
    Good Luck.
    Bob
    Leave a comment:
  • Mashermoto
    replied
    Checked the big honk'in new battery this morning and the charge light is green...meaning I'm good to go
    My cold symptoms are not as bad today so I'm off to work this morning. Tonight I have to help some 6 and 7 year olds learn bible verses at church...bless their little hearts
    So, Thursday night I'll be back in the Man Cave...man I hope that solenoid is bad I'm thinking the way to thread the coil wires back through once opened up is to tie a little thread to each wire and pull them through that way
    But I know...I know...first check the ground connections, install the battery, then see if it works I also need to set the timing like Pete mentioned. I hadn't thought about that...actually I should be able to align the timing plate to the F mark then rotate the pulse coils to line up with the reluctor. That should get it close enough to start
    Well, I got to get to work to pay for that battery I bought at Wal Mart yesterday
    In the meantime, I'll give you guys a topic to discuss. The Partridge Family was neither a bird or a family...please discuss at will
    Leave a comment:
    replied
    The World is Flat and Atlas Holds it Up.
    Thanks Cy, Crazy Steve.
    I'm ok with learning new things but it really bugs me when I find out that something I knew to be true just ain't so...
    Next time I have to pull a starter I'm gonna ....I mean I'll ....
    Nope. I prob'ly should ask the wizard for just a little more courage next time I'm in the Emerald City.
    Leave a comment:
    replied
    Originally posted by Larrym
    Crazy Steve,
    Nice "side-bar" dialogue goin' on. Just the type of stuff that makes this site worth putting in the favorites bar.
    Uh, ummm. So I believed that the starter motor on our bikes was/is a series wound DC motor just like the kind used in cars: Max torque but has to have a mechanical load or it'll spin up fast enough to destroy itself. I've seen people "bump" an uninstall-ed automotive starter and it jumps unless a foot is on it holding it firmly in place but I've never seen them keep it connected so it runs continuously. I dunno..our starters might be a shunt or compound and therefore be safe to hook up to a battery while the unit is uninstall-ed/off the bike.
    So I've never bench tested a motorcycle starter by hooking it up to power and letting it run continuously.
    Have I been wussing out for no good reason cause it's really ok to do this?
    Never mind...I wouldn't be able to get past the arcin' and a-sparkin' when making the initial connection.
    The starter installed in the XS is a series-wound motor, as are nearly all the starter motors I've ever seen. And it's not a 'DC' motor either; this type is called a 'universal' motor and it would be perfectly happy running on 12v AC (The only 'true' DC-only motors are ones with permanent magnets in lieu of field windings). If you run it no-load, at some point the impedance gets high enough to limit current and maximum speed. Is it 'good' for them to do this? Who knows? I doubt that it would spin fast enough to throw any windings or commutator segments but it will definitely shorten brush life, and I doubt if the bushings used in these would like the high rpm; but to bench test, no problem.
    Although I did see a 'homemade' kiddy car that a guy built using a couple of car batteries and a car starter as the motor. He had gotten hold of some big old industrial reostat for the speed control. The kid could literally 'smoke' the other kids with their store-bought electric cars, and it could do mini-burnouts! But it was too fast, so he ended up pulling the 12v batteries and putting in 6v units to slow it down. One of the downsides was you couldn't quick-charge it like the storeboughts; once the batteries were low, it was put up until the next day. It did eat motors too, but he was getting them out of the boneyards so who knows how used-up they were to start with...
    '78E original owner
    Leave a comment:
    replied
    Crazy Steve,
    I have run a starter without it installed. It didn't grenade, it spun up a good bit, and it jumped when it started spinning because there is a LOT of torque there, but any time you have a conductor moving through a magnetic field you get inductance. Be it a pulsed DC field as you have in a starter motor, or an AC field, you get a moving magnetic field which induces an apposing current, which equals inductance. All electrical motors change their inductance with load and speed, they draw the most at startup/low speed and the least at max speed/load. This is just part of basic electrical theory.
    I may not be a master mechanic, but electrical and electronics has been my primary field of interest and study since high school. That's why a bad starter can make a good battery look bad, because if it doesn't spin properly it draws more current, putting a greater load on the battery than it was designed to handle.
    Leave a comment:
    replied
    True or False?
    the difference is the impedance. As a side note, this also limits maximum motor rpm, so you can't have a 'runaway' motor.
    '78E original owner
    Crazy Steve,
    Leave a comment:
  • clcorbin
    replied
    You are absolutely correct! I was thinking about what happens to an induction motor when you decrease the voltage to it, even under a fairly trivial load to decrease the motor speed. I'll claim the excuse that my fingers fired before my brain did! But either way, my statement was wrong and your rebuttal was very through.
    Sorry, not true. Any electric motor, whether it's AC or DC, operates on the same basic principles. If you calculate current draw for the Yammy starter assuming it's 'purely resistive' using the service manual figures, what you'll come up with is this:
    It's series wound, so you add the field and armature numbers: .007 + .01 = .017 ohms. Plug this into the equation and you get I=12/.017. This comes out to over 700 amps! I don't think that little battery and skimpy wiring can deliver that....
    The factor that makes it all work is impedance, or more specifically, inductive reactance. This is also measured in ohms, and would be added to the circuit resistance. This also increases with frequency (in this case, motor rpms), so the faster the motor spins, the more impedance i.e. 'resistance' you have. Larry got about 80-90 amps in his test, so using R=V/I, you get: 12/90=.133 ohms. This is almost 8 times the 'measured' amount, and the difference is the impedance. As a side note, this also limits maximum motor rpm, so you can't have a 'runaway' motor.
    Another way to look at this is via the 'power' equations, and this will show why current goes up for a given load if voltage goes down. One HP = 746 watts. So to produce 1 hp with 12v; P/V=I, or 746/12=62.16 amps. Lower the voltage, amps go up; 746/9=82.88 amps. So good connections become very important if they're reducing the voltage to the load.
    How much HP does the starter motor produce? Using Larry's numbers, just a bit less than 1.1KW, which is very typical of a big-bore bike starter.
    I'm not trying to bust anybody's chops here, but a lot of you seem eager to spend Mashermoto's money before he's eliminated all the possibilities; I've never seen throwing money at a problem as being the best way to go about it...
    '78E original owner
    Leave a comment:
    replied
    Originally posted by Mashermoto
    ... is it possible to get inside an OEM solenoid?
    Yes it's possible. As you suspected there are two short wires that keep the top from coming off when you remove the screws. If they're not broken you have to de-solder them to get the top off of the solenoid. If they're broken the solenoid won't work or it will work intermittently, like when you put test leads on it to find out why your bike won't start.
    This is what the solenoid looks like inside with the top cover and plunger removed.
    ... removing the starter cable ... I don't remember the voltage at each point, but I do remembe that I lost 3v to 3.5v.
    Is that a normal drop in voltage?
    No, it's not normal. If it's not another random case of, "Oops, I measured the voltage drop again and it's fine now!" then the internal contacts are worn and corroded. Unfortunately you have to de-solder the two solenoid coil wires to get the top off to clean the contacts.
    Getting the two wires back in their holes and re-soldered isn't easy and takes some patience. It might be easier to get another solenoid.
    Regards,
    Scott
    Leave a comment:
  • joceiphus
    replied
    Was that not the best show EVAR?
    Leave a comment:
    replied
    Pins and Needles
    From Ren/Stimpy: SPACE MADNESS
    (Stimpy marches back and forth, staring at the button.) ANNOUNCER Oh, how long can trusty Cadet Stimpy hold out? How can he possibly resist the diabolical urge to push the button that could erase his very existence? Will his tortured mind give in to its uncontrollable desires?
    (Announcer grabs Stimpy, forces him closer to button) Can he resist the temptation to push the button that, even now, beckons him ever closer? Will he succumb to the maddening urge to eradicate history? At the MERE... PUSH... of a SINGLE... BUTTON! The beeyootiful SHINY button! The jolly CANDY-LIKE button! Will he hold out, folks? CAN he hold out?
    STIMPY NO I CAN'T!!! EEEEEYAAAHHHH! (pushes button)
    (Alarms go off. Ren, Stimpy, and Announcer stand around table w/ button.) ANNOUNCER Tune in next week, as... (Flash, explosion as they all disappear.)
    Leave a comment:
  • Mashermoto
    replied
    Ah hah
    You do have to un-solder the coil wires:
    I hope this solenoid is bad because I'm itching to open it up
    Leave a comment:
  • joceiphus
    replied
    God's selonoid, Baby!
    Leave a comment:
  • Mashermoto
    replied
    I did actually do the test twice and got the same result.
    As Paul Harvey used to say...and now the rest of the story.
    After my second attempt the solenoid acted as though it was stuck in the off position. In other words it wouldn't work when I pressed the button. My lights would slightly dim, but no contact at the solenoid. It could just be coincidence that the battery just happened to be low enough to not even power the solenoid But I didn't think it would hurt the solenoid to do this test without a load on it.
    I'll search for that post about a solenoid disassembly. I think the trick might be that you have to un-solder the wire leads to the coil.
    Nope, not afraid of exploratory work...that's how we learn about stuff like this. If it still won't work with a good battery, I'll prep the patient for surgery
    Leave a comment:
    replied
    Robert's Rules of Order
    Mashermoto,
    Cool to consider different options/strategies at this point but.....
    As a point of order in the troubleshooting process it's important to take care of old business before actually moving on to new business. Getting the new battery takes everything back to square one where the same function/voltage tests need to be done but this time with a known good battery. (IMO...but other members of your virtual pit crew may differ..)
    Twists and turns...dead ends....ups and downs....back to the start and running just to keep still.
    No wonder Alice always had that confused look on her face.
    Last edited by Larrym; 02-23-2010, 06:51 PM. Reason: The white knight always talks backwards.
    Leave a comment:
    replied
    Post Mort-em Actions
    Ok Mr. Microphone Man
    In anticipation of what I think my next problem will be, is it possible to get inside an OEM solenoid?
    As mentioned earlier I did a test on the solenoid by removing the starter cable. Then I read the voltage of the battery with key off. Then I placed my volt meter across the negative terminal of the battery and the starter side of the solenoid. I turned the key on and pressed the starter button and read the voltage again. I don't remember the voltage at each point, but I do remembe that I lost 3v to 3.5v.
    Provided that the measurements were taken with the starter cable removed from the starter side of the solenoid with the meter leads placed as you describe...
    Not by any means. Period. The solenoid when engaged should provide a dead short (or as close to a perfect connection..) between the two lugs. If you read a voltage drop without a large current flowing and only the trivial amount needed for the meter to do it's job then there's a problem in the solenoid.
    Apparently. I'm usually anal retentive enough to perform the test at least twice to confirm/reproduce the readings. (Part of an officially recognized troubleshooting "redundancy" method so that valid info from testing is used to make the official decisions.. As a bonus it bolsters the self-esteem of anyone who really is anal about stuff..)
    Test again and if it's truly a fail then it's dead already and a good candidate for "exploratory" disassembly/repair/reassembly. I haven't done that myself but there was a post of someone doing just that and achieving a working solenoid.
    After all if it's officially a dead component then with the odds being 50/50 of achieving a working solenoid then maybe even in death the solenoid can be of value.
    You're don't get squeamish/light-headed around burned contacts, carbon, and component Guts, do you??
    Leave a comment:
