Ive actually got a several pics of your setup saved already. I dont see it as being overly difficult, just time consuming.
One question though, did you cut down the swingarm at the pivot tube on either side or have any centering issues?
My XS11 Project - Juggernaut
Leave a comment:
Today was a big day for the parts fairy. got my complete swingarm and assorted bits, Busa shock, tank, and busa forks. Suprisingly, the busa forks are even shorter than the R1 forks are by about 1-1/4", this is going to really lower this thing. Hope its not too much. Now that I can actually look at the tank, I LOVE it, I really like the color too. Kind of a gun metal blue metallic. I dont think the monoshock fabrication will be as bad as I originally expected, but the swingarm pivot mount is going to be a pain.
Leave a comment:
Cannot say forsure, but the rear wheel specs is about what I have on Bones, with as far as I know a standard swingarm with a 750FD.
Bones is in the workshop, will let you know tomorrowLeave a comment:
The FJR swingarm has an open U joint instead of a tube covering it to the middle drive like the XS, so the pivot on the FJR swingarm is narrower since it does not reach the left side of the frame. So it will need a new mounting point fabricated to bolt the left side of the pivot to and still clear the ujoint. I also have to do a monoshock conversion on the frame. I forget the final gear ratio, but IIRC i think it was a bit higher than stock XS. It should allow up to a 190 tire or so. I plan on running Pirelli Diablo Stradas. 120/70/17 front and 190/50/17 rear.
Ill get back to you on that cover.Leave a comment:
Fly wheel cover
Have one for cost of shipping. It has a ding that will need weld or body filler. About 3/4" indention at bottom face. Will get pics if you want.Leave a comment:
How's that swing arm and final drive work out? Will it bolt up to the xs frame or do you have to modify? How is the gear ratio? It is going to allow a wider tire, right? Project looks good!Leave a comment:
Well the R1 forks are about 29-1/4" from axle to cap and uses a 23-1/2" tire (120/70/17). I imagine the Busa specs are not too far off, and the tire is the same.Leave a comment:
Im not sure how long the busa forks are in relation to the FZR forks, Ill know that tomorrow, but I dont think theyre much shorter, if at all, and might actually net a higher ride height due to the forks being more suited to the greater weight. But needless to say, tuning the suspension in will take some time and finesse for sure. I dont need this bike to be the best handling thing around, and I do want performance out of it, but hopefully not compromising comfort too much since this will be my highway bike, but theyre mountain highways. If I want to play in the hairpins, Ill throw my FZR into the canyons and have all the handling I could want. but the FZR kills my wrists in short time. But it was built to have razor sharp handling, and not so much comfort.This should be much better for longer trips and Im actually planning the build around making it more highway friendly in the end. Things like tail options, (eventual) passenger seating, exhaust placement, and luggage(but removeable soft sport bags only). But the goal is to get it rideable first, then Ill start working on the highway accessories. I find it fun trying to balance everything in the build. Makes it interesting and original.
Im sure I will be bugging you quite a bit in the near future with questions about your setup, its given me a lot of motivation.Leave a comment:
I love these kind of projects! Nice swingarm as well
This means a longer wheelbase as well for more stability and comfort on long sweeping roads, not that brilliant in hairpins however... maybe it will work out fine with the shorter forks.
Leave a comment:
Fork Length...
My stock 80G forks measure 31 7/16" From top of air cap to center of axle. HTH P.S. they are outta da bike
Leave a comment:
I'm sure someone on here will have a set of forks outside the frame and be able to measure it for you to give you a base figure. I am guesstimating that the busa forks will be longer, and might just give it a slicker look. Other possibility is that they are shorter, which might cause a problem on your back. might have to drop the rear on the mono shock to keep the look balanced.Leave a comment:
It should actually lower the front end a bit. But since i dont have and never have had a set of XS11 forks, so i dont have a base for comparison. But Ill have some basic measurements in a few days.Leave a comment:
Please keep us (me) posted on this one. Would love to see how much lift the busa forks does on it, and might be a worth while conversion on my side as well.Leave a comment:
For the rear wheel, I will be using the stock FJR1300 wheel for now, which runs a 180 or 190 tire. That will get the bike rolling, then I am planning on fitting a R1 wheel in place of the FJR wheel since the two have the same size cush drive. Plus the FJr wheel is a 3 spoke and a fairly close match to the busa front wheel. As for fitting the forks to the frame, its only a matter of a special bearing and a small spacer on the Busa stem since its a bit longer. I wont be bothering with an ABS setup, just conventional braking. Ill be using the stock busa 6 pots up front, and the FJR rotor and caliper. The caliper appears to be the same as early R1 calipers, and also comes with a brembo MC that looks like it might bolt up.
Fitting up the swingarm will require some considerable fabrication to the frame both for the pivot mount and a monoshock conversion. It will also need the middle drive spaced out 30mm or so for the driveline. But that comes later, first I need to finish the chassis fab, then Ill deal with the engine.
This bike is intended to be sporty, but more comfortable than my FZR so I can take longer trips in the moutains and not have my whole arm go numb. But it wont be a long-hauler I dont think. Just short weekend trips and such.
Ive strongly considered the FI swap, but thats not going to happen in this phase. I want to get it simlpy running well and rideable as soon as possible, and then make more upgrades as I go. I dont want this build to take 2.5 years like my last one.Last edited by MrFreeze5; 12-05-2009, 12:11 PM.Leave a comment:
Leave a comment:
