Hey Freeze, First off...Cool build there.
I do have a question that maybe Math can also answer...Does the driveshaft on the FJ arm angle out at the rear? I was always curious how Math put the larger rear tire on because the XS11 U-joint and shaft at the straight back direction only allows for a skinny 140 (150 if inner swingarm is ground out near the tire wall)
I never bothered asking him before, But when I looked into doing this arm upgrade before, I came up with a drawing of a piece that could possibly bolt right on to the XS frame and clear the U-joint. I'll see if I can find it.IIRC I would have had to weld 2 stop tabs on the left frame upright and call it a day.
BTW is the Honda tapered bearing a go?
My XS11 Project - Juggernaut
The engine is now in the kitchen where it will remain while I work on it. After getting the engine out of the truck and into the house I have been able to determine a few things. When I bought the parts bike for this engine I was told that it had been rebuilt and not paid for. The bike sat for a while at the shop then ended up at the salvage yard. It hasnt been registered since 04 so I was a little concerned. After getting the engine out, I noticed that the cylinders are not original. The engine is in great shape, no leaks, just a little dirty on the bottom. The spark plugs are damn near new and the engine turns over smoothly. To top it off, my buddy has a tiny flexible scope and I stuck it in the spark plug holes to check the cylinders and the bores are clean with a good crosshatch and the pistons have only a light coating of carbon, not a spot of rust or corrosion that I can see. And there is just a tiny bit of surface corrosion at the intake ports on the outside of the head. All in all, I think I can trust the innards of this engine since I dont really have the space, time, or budget to tear into this engine, especially if it doesnt need it. These engines are pretty damn burly, so I am going to put a little faith into it.
Once the buildoff is over I will very likely start devising a hopped up engine for it, but the goal is to have a running and rideable bike by the deadline.Leave a comment:
This is great seeing a project like this .
I like the fact that you are experimenting with this, as it takes the hard work out of guessing what to use for us others who dont have the time or space.
looking forward to seeing the end result for sure.
It gives me the urge to start on my third bike, an XS trike. some of your ideas are veri inspiringLeave a comment:
I pulled the engine from the donor bike and finally got it out of my Jeep. Ill start stripping electrical this weekend or next week from the donor. That engine is a beast!
Leave a comment:
Its all just mocked up right now to get a visual for the fabrication necessary, which I will probably get started on next week. The rear is higher because thats as low as I could get it with a sideways jackstand. I need to get a rear wheel before I can do any final work though since the swingarm is asymmetrical Im not sure exactly where the centerline is. So once I have the wheels I can work out ride height amd suspension tab position. the front forks wil lower the bike quite a bit, so I will more than likely have a new upper triple tree made to give me a little extra height out of it so i dont have clearance problems. I need to drop the rear too, and can evaluate that once I have the seat in place I am going to use.That looks like a NICE conversion!!
My only thought is the swingarm is in the "compressed" position, correct?? The front and rear axles should be about the same height off the floor, I think. The tire diameter from front and rear should only be about 2" off. The front forks put the axle almost on the floor, and the rear is up about 6". The mount for the shock should be closer to the rear tubes, not the front ones. JMHO
Again, LOOKING GOOD!!Leave a comment:
Das Boot(s)but somehow i dont think you are going to get very good cornering or milage out of that front "tire" there.....not even if you put its mate with it
Leave a comment:
Looking good so far!!! but somehow i dont think you are going to get very good cornering or milage out of that front "tire" there.....not even if you put its mate with it
Betcha that living room is about 60-70 degrees warmer than my garage (im
jealous....SWMBO would string me up by my tight curlies if i tried doing that!!!_Leave a comment:
Got the exhaust today and it looks great. Did a little mockup, me likey. Theres another can for the other side, but i ran out of zip ties
Leave a comment:
Here's a nice little bonus. I bought a Ducati Monster clutch system for the slave cylinder and stainless line it had to use on my FZR hydro clutch conversion. Got a good deal on it too, but the whole thing came with a master cylinder too. I already have a few Yamaha slave cylinders for the XS11 hydro clutch conversion, and my stock clutch cover is at the machinist to have a new one made to mount the slave to. This master cylinder is a Brembo and although it is simple, its essentially free for this build and will match the Hayabus brake MC I need to use with the 6 pot calipers until I can afford aftermarket radials. Eventually, I am going to use a radial clutch MC just like I have for my FZR. Its from an Aprilia and it is oh so sexy, but for the purposes of functionality, Ill use what i have to get it going.
Leave a comment:
There are casting marks on my swingarm around the bearing cup on the pivot tubes, round and square marks. They are 3/8" from the edge of the casting marks to the outside edge of the swingarm pivot on both sides. If yours has the same marks, it would be a good reference point.
These are the only pics Ive got at the moment, Ill try to snap some closer ones later.
Leave a comment:
Ill snap some closer pics, but from the looks of the pics I have of your ride, it doesnt look like it was modified. And if it was, it would have been a somewhat involved process since there really isnt much material that can be removed. Its just been kind of a PITA to try and find the centerline on this asymmetrical swingarm without having a wheel on hand yet. I think Ive got it pretty close and I dont think any swingarm modding would be necessary. I am really surprised at how close everything seems to fit. Its should be pretty straightforward as far as the frame mods go, and the monoshock conversion is 10x easier than i expected it to be, but I will still probably overbuild it.Can't remember and as the swingarm has been powdercoated i can't check. Send me some pics from the sides of your swingarm and i will compare them with mine.. And the stock FJR shaft fits one on one to the XS without a single mod. That is if you keep the standard XS swingarm pivot.Leave a comment:
The yokes interchange from what i understand, but I have not checked yet.
A teardrop tank wouldnt look right with the tail I want to use. When I saw this one, it spoke to me. Its definitely the right tank for this build.Leave a comment:
Probably a dumb question
The shaft on the new swing arm, is it directly compatible with the XS or do you have to fit a different type of CV-yoke in there?
Nother question that got into my head. Wouldn't a 17 Litre teardrop tank go better with the conversion?Leave a comment:
Leave a comment:
